Pages: [1] 2  All   Go Down
Author Topic: Flash 10 seems to be Ok now  (Read 12198 times)
« on: July 27, 2009, 12:02 PM »
Just wanted to let people know that Flash 10 seems to be working for alot more people without problems.  I've been using it for almost a month now with no ill effects.  Install at your own risk...just saying that it's working fine for me now.
If you do have problems with 10, you can go back to 9.  I know King has a guide here on how to do that, but I use one that I made from information received from Adobe (the maker of Flash).  So try Kings first.  If it doesn't work, do the following:
ok. I'm assuming MS Windows in this help file, so Mac users can follow the instructions on the Adobe site (using pretty much the same links I provide below). Also, do the following at yer own risk. I accept no responsibility for anything bad happening to yer pooter (my lawyer made me say that ;). Make sure you read all the documentation located at the following links as well as the 'readme' file in the main folder of the file you are going to be downloading.
First you need to uninstall flash 10. There is a special utility adobe provides for this at the following link. The link you want is "Windows:  uninstall_flash_player.exe (205 KB) (updated 2/24/08) ":
http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_14157&sliceId=1
MAKE SURE YOU FOLLOW THE INSTRUCTIONS ON THE DOWNLOAD PAGE EXACTLY FOR THE CLEANER APP TO WORK PROPERLY. Make sure all other programs/windows are closed before running the 'clean' program. reboot yer computer after the 'cleaning'.
Next, go to the following link and download the archived flash 9 app (it's a 166 MB file because it contains every version of 9 for every OS that adobe released). What you're looking to download and save to your computer is "Flash Player 9 (166 MB) ". Grab a quick cup of coffee or your favorite beverage while you wait for it to download. It took 6 minutes for me to download via broadband (3Mbps):
http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_14266&sliceId=2
Now you want to extract/unzip that file you just downloaded into a temporary folder on your computer. The next part is the tricky part. You are going to look in the extracted folder named '9r151' for the proper '.exe' file to run. This will depend on whether you're running IE or Firefox:
If using IE, the file you want to click on and run is: 'flashplayer9r151_winax.exe'
If using Firefox, the file you want to click on and run is: 'flashplayer9r151_win.exe'
Once you have run the appopriate file, Flash 9,0,151,0 should now be installed on your computer. To verify this, click on the following link, which will tell you which version of flash you have installed:
http://www.adobe.com/products/flash/about/
At this point, you are finished.
If you get a popup or some other alert telling you there is a newer version of Flash available, then you have an auto-updater enabled on your system. There are ways to disable this, but I'm not going into that yet unless someone has that problem. Go ahead and try my tutorial. If you get an alert or popup, post back in this thread, and I'll continue on as to how to disable the auto-update feature.
Some important notes:  Download the 'clean' tool. Save the file to your Desktop or Downloads folder. DO NOT CHOOSE THE ‘Run’ or ‘Open’ OPTION.
Then: close all running applications including Internet Explorer, Firefox, Instant Messaging Software (i.e. Live Messenger, AIM, Yahoo Messenger, MSN Messenger, Skype, etc.). Look in the bottom-right of the system tray / taskbar to make sure the you have truly quit them and that they are not running silently in the background. This is because they tend to use the Flash Player too and the tool cannot remove files that are in use.
Then: run the Removal tool from where you saved it. The tool will remove all versions (past and present) from your system. At this point, there should be NO Flash on your computer. To check this: after you 'clean' and reboot...BUT BEFORE INSTALLING FLASH 9...go to the 'version check' link I supplied in my earlier post to make sure that Flash is gone from your computer. Please let me know what it says on that page (whether it shows that Flash is not installed or whether it shows version 10 is installed).
Continue with installing version 9 if it says that Flash is not installed. DO NOT CHOOSE TO INSTALL FLASH IF YOU RECEIVE ANY POPUP OR MESSAGE ASKING IF YOU WANT TO UPDATE/UPGRADE! That will put 10 right back on your computer. Use the file supplied in the download to install Flash 9.
Flamanar:  Flame...Flash...so appropriate together...
« Last Edit: July 27, 2009, 12:23 PM by flamanar »
Re: Flash 10 seems to be Ok now
« Reply #1 on: July 27, 2009, 05:02 PM »
Hey Flame!  After I saw you and Fun yesterday and continued on with my test of Flash 10 (on my computer at home with Windows Vista) in the VFK Pool areas, I did notice short little periods of lag (which I don't have with Flash 9).  Have you experienced the same?
As I mentioned to you, there are so many other sites now where Flash 10 is needed (Disney, Facebook & MySpace just to name a few).  VFK really needed to get this issue resolved once and for all.  So, I'm crossing my fingers!
« Reply #2 on: July 27, 2009, 05:05 PM »
Flame - you have me soooo confused with all the wordiing thingy stuff ya said  :??:
Disco, glad to catch you last night! I have lag anyway no matter   :lolg:
« Last Edit: March 09, 2015, 03:59 PM by funfly »
« Reply #3 on: July 27, 2009, 05:16 PM »
I'm still running on 9.... LOL
« Reply #4 on: July 27, 2009, 05:18 PM »
Yeah...the problem is that many sites now require Flash 10 to even get onto them.
I do have some occasional pauses, yes...but I'm not sure that it's Flash 10 since I've been using it since before the pool opened.  I'm assuming it's the pool and VFK changing things in the background...but no way for me to tell now without going back to #9.
Fun:  LOL.  Sorry about the wordiing thingy stuff :)  I'm glad to announce, however, that I'm publishing an Ebook for download that explains exactly how to go back to Flash 9 from Flash 10... :tongue3:  NOBS members will get it for free...everyone else will pay through the nose ;)
Flamanar...the above paragraph is commonly referred to as a 'joke'...or 'humor'...if you don't know what those words mean, you need to get a life... :uhuh:
« Reply #5 on: July 27, 2009, 05:44 PM »
OMG Flame! As soon as I read your 'humor' paragraph starting with 'Fun:...." and the rest  :rofl1: :rofl1: :roflmao: :rofl1:
All I can say is....I am SO GLAD I swallowed that coffee in time!  :rofl1: :roflmao: :rofl1: :roflmao:
Oops, wait, - getting a cloth -  :rofl1: :roflmao:
« Last Edit: July 27, 2009, 05:46 PM by funfly »
« Reply #6 on: July 27, 2009, 06:05 PM »
Ahhhh...so glad there are people that appreciate what good humor is :)  Anytime you wanna pass coffee through your nose, just let Flame know ;)
Flamanar...Coffee makes the world go around.....FASTER....
« Reply #7 on: July 27, 2009, 06:16 PM »
Flame, you can borrow my editor!!! She will be more than gladly to blurb it!
« Reply #8 on: July 28, 2009, 10:52 AM »
I don't need no steenkin' blurber!  ;)
Flamanar...hey, they can't be funny all the time...
FilamentTheBright
  • Is it Bright in here
    or is it just me?
    A Well Gnome Flasher
  • Trading Gnome
  • Pirate Cannon Room
« Reply #9 on: July 28, 2009, 11:08 AM »
When did they start being funny?  :rofl1: :rofl1: :rofl1:
Sorry, it was too easy.
« Reply #10 on: July 28, 2009, 11:27 AM »
Oh my Gosh!!!  :rofl1: :roflmao: :rofl1: :roflmao:
« Reply #11 on: July 28, 2009, 12:21 PM »
LOL.  I refer all questions concerning humor (or lack of) to my lawyer...who is a complete Bozo and should be able to answer it based on his own personal experience.  :roflmao:
Flamanar...needs a clown emote...  :P ;)
FilamentTheBright
    or is it just me?
  • Trading Gnome
« Reply #12 on: July 28, 2009, 12:27 PM »
 :jester2:
This is as good as it gets for clown emotes.
Unless you want to try this one?
 :jester:
Are you sure you want Bozo?  I know someone who's lawyer is Homey the Clown.  He's cheap.
« Reply #13 on: July 28, 2009, 12:32 PM »
I've been using Flash 10 the whole time. I switched from using Explorer to Firefox after Explorer crashed on me a few times, and it never really had a problem after the switch.
« Reply #14 on: July 28, 2009, 02:31 PM »
I think I am going to make an appointment with the shrink now..... :phone:
« Reply #15 on: July 28, 2009, 02:44 PM »
:jester2:
 :jester:
Does he accept Visa?  If so, I'm sold...  :victory:
On a different note, I recommend anyone having problems with VFK try Firefox.  It's got a small footprint, and Flame lurves it.  Small learning curve, but hey...that's life! :2thunbs:
Flamanar: :jester: <<----that kinda works :)
« Reply #16 on: July 28, 2009, 02:59 PM »
Explain the small footprint... consfused... :shy:
Pages: [1] 2  All   Go Up
